跳转到主内容
Released on June 23, 1996, Model NUS-001, 64-bit gaming console
Why won't the TV recognize my N64?
Hi! I was feeling pretty nostalgic recently and got an N64. It worked for a few plays, but I've been trouble recently. The N64 turns on just fine, but the TV won't recognize it---it gives me a "no input" error.
I thought it might just be AV cables going bad (they were pretty old) so I replaced those, but no dice.
I did just get an expansion pack to play Majora's Mask, but it worked after that for about one play. Since then it hasn't.
I've tried different ports to make sure I have the AV cables in the proper place, and nothing appears to help. I've plugged it into TVs not connected to satellite, I've disconnected other gaming devices, I've tried everything I can think of. Does anyone have any suggestions?
i've tried it on multiple television sets, by the way, in different households.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Probably logic board failure. I would recommend getting a new one.
完成的
添加一条评论
1个答案
已选择的解决方案
Rachel, hope it has worked on the newer TV's before. Anyhow, I would suggest that you clean the cartridge slot first, follow this guide. After that, it is time to open up your console, use this guide, and check for any obvious signs of burned or loose connections. Check for broken solder contacts near the power switch and near where the power pack plugs in. If you are handy with a multimeter, I think I even have some schematics for this console. Hope that helps, good luck.
Nintendo 64图片
指南
How to clean the Nintendo 64 cartridge slot
难度:
非常容易
5 minutes
Nintendo 64 Motherboard图片
指南
Nintendo 64 Motherboard Replacement
难度:
简单
15 - 20 minutes
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Rachel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 7,836
