跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
Can I install a 2009 logicboard into a 2008 MacBook model?
I have a Penryn white plastic macbook. I was wondering, if I need to install a new logic board, are the latest 2009 macbook logic boards compatible?
I see it has a sata connection for internal optical drive, so that's a "problem". But other than that, would it fit?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The logic board from this machine would be as high as you can go:
Apple MacBook "Core 2 Duo" 2.13 13" (White-09) Specs
Identifiers: Mid-2009 - MC240LL/A - MacBook5,2 - A1181 - 2330
这个答案有帮助吗?
得分 1
1条评论:
Yes, I found that indeed. However, an answer on another similar question shows that you'll also need a new bottom case, because the 2009 model has different screw positions. So, I guess I won't attempt. (Swap late 2008 Black MacBook logic board to Mid 2009 logic board?)
完成的
添加一条评论
添加你的答案
Peterdk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 278
