I experience this one today. I use my phone on taking photos while I'm in the pool. At first, the phone only detected that there is a moisture inside my port. Until I decided to used a hair blower to get rid of it. And then, there is no longer notification. Afterwards, I charged my phone. A few minutes later, an indication of moisture detected. And so I detached the my phone to charging cable. Then, I use my phone to take photos again.
But then, when I turned it on, there is a sign of damaged lines like there is a darker lines and normal lines. And I thought this won't last. Then, I took pictures only in front camera since there is a sign of moisture inside the back camera. And so this suddenly happens..
After taking photos, I do edit pictures through phone. And suddenly, with a 26% battery, my phone blacks out. ??..I started to panic since I've tried all the solutions I have searched in the internet.
And I finally, decided to open the phone trying to fix it myself since I can't afford to pay repair for this in the service center. I found some areas wet. And I tried to open it using the Power On + Volume down. But still nothing works after cleaning. (I didn't do unscrew anything).
The last thing I did today was use an UV sanitizer that I bought in the midst of pandemic. I only put the phone that I opened at the back in the UV Sanitizer (for about 10-15s) and I use the solution I found on making it open ( Power On + Volume up for a 10s). And viola my phone is now working. I am so happy that I want to share to everyone what I did to fix my phone (S10e). Hope it works for you also. I think UV devices can help dry the moisture inside the phone. Feedback me at alleyiahshyne@gmail.com
can anyone help me b/c my lg g stylo fell and now the screen is black and i dont know what to do....plz help
由 Helder Villanueva 完成的
i have the same problem. my samsung e5 mobile has dropped down, now i cant able to see the display, the display is blank now after changing the display also, can anyone help me please
由 Ramesh Nice 完成的
i took my Samsung S6 active to the pool and water got inside the phone, now the screen is purple and pink and the screen is barely visible but it still functions , and i dont know how to fix it
由 Jonathan Campos 完成的
Please make sure your phone has been completely dry for the first time. There are two possible causes make your mobile phone stuck in black screen: The hardware inside the phone is damaged, or the OS is damaged.
You can try using the Samsung Data Recovery to get Samsung out of blank screen, and restore you lost data from Samsung with black screen.
Read more from: https://www.youtube.com/watch?v=f6bOgiUf...
由 feiyer 完成的
<a href="https://www.youtube.com/watch?v=XELRW1-u... ">try this out</a>
由 anuragsharma2479 完成的
显示更多的21条评论
