跳转到主内容
How do I test 14 pin power supply?
How do i test this 14 pin power supply, ie what cables do i jumper and what do i use for ground. Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
akshay patel, you connect PSON (pin 4) with +5VSB (pin 5) to turn it on. You do want to try this with a resistor across the pins first. This PSU may also require a load in order to stay on, so attach a drive or similar to it as well. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
4条评论:
14 pins to 24 pins howto solved
完成的
Rk Lab not sure what you are asking. This is a question?
完成的
I've 14 pin compaq pc power supply i turned it on but it will turns off by itself in a few seconds i want to make it lab bench power supply so I don't wanna add any drive or something to it please give me some advice on how to make it stay turned on what components should i add?
完成的
Same problem Pateh khan
完成的
添加一条评论
I need a 14 pin ATX power supply tester please
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
akshay patel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 109
总计 19,746
