跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
iPhone 3GS missing components
L85_RF AND L3_RF missing please what do I do?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
已选择的解决方案
Jaywn, there is absolutely no reason to replace the board. L85_RF is the "blue inductor" 1.2NH-1.36A-0.045OHM and as you probably already know, some people do bridge it by using a circuitwriter pen or similar tool. L3_RF is another inductor, values7.5NH-1.4A-0.080OHM. I would replace both of these components. They are readily available, but a bit hard to solder to the board due to their size. You'll need good tools and excellent skills. Both of the inductors are part of the cellular antenna circuit, your phone will not have any service without them. Total cost for both pieces should be less than $5.00, hope this helps,
这个答案有帮助吗?
得分 0
2条评论:
Thank you. Do you know where I can find these parts?
完成的
It depends on where you are located. I would start with mouser .com or digikey.com. Thank you for accepting my answer.
完成的
添加一条评论
If the phone works, do nothing. If it does not work, replace the logic board.
这个答案有帮助吗?
得分 0
1条评论:
Hi. It just searches. Where can I find the L85_RF component or can I just bridge across?
Thanks
完成的
添加一条评论
http://forum.gsmhosting.com/vbb/f631/3gs...
Here its the solution!
这个答案有帮助吗?
得分 0
1条评论:
Same as in the original answer
完成的
添加一条评论
Yes, is possible in Mouser-DigiKey,etc. Cost about £ 0.010 the spares and £ 15 for shipping + VAT.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jaywn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 326
