跳转到主内容
加入维修社区 - 创建账户
Also known as the LG Splendor, an incarnation of the LG Optimus L7, sometimes known as the LG Snapshot or Swift L7 under the model numbers US730 and LG730 depending on carrier.
I can't find a guide to replace screen
I've been searching all over YouTube and a couple of websites but i cant seem to find a guide for the LG Venice/Splendor, I've seen similar phones that LG manufactures which have the same repair steps, would this phone file under other phones in means of repair guides?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Much thanks :) i really appreciate the guide and response time thanks again :D
完成的
you are welcome. Best of luck to you and thank you for accepting my answer.
完成的
添加一条评论
3个答案
已选择的解决方案
alcranking, try this:"
Take apart the battery cover using notch below
Take apart the battery and remove screw (12 point)
1. Unfastening the hook, make gap between Rear Cover and Front Cover
2. Widen the gap between Rear Cover and Front Cover and hook off starting from below side (back view)
1. Take connectors & Side Key FPCB (1~9) out of the Main PCB
2. Widen the gap between Front cover and main PCB
3. Remover the Bracket Camera to upper
1. Unfastening the hook from below side, sh back side of LCD through a hole on back side of Front cover
2. Take apart Frame out of Front cover
1. Lift LCD from the frame & Take off the LCD.
2. Be careful. Do not tear the LCD FPCB
I always wonder about the grammar in service manuals :-) Hope this helps, good luck.
这个答案有帮助吗?
得分 4
4条评论:
So this is a screen replacement guide for the LG Venice? Please correct me if I am wrong.
完成的
Jabran, yes it is
完成的
Hey old turkey, I am grateful of the pics you put up to fix the lg Venice, but could you please make a video, because I cannot understand the pics that we'll. if you could send me the video on my email that would be great. Husban_shahid_7@hotmail.com
完成的
Sorry Husban., I did finish the repair and do not have the phone anymore.
完成的
添加一条评论
Okay I follow just didnt remove the lcd I simply replaced the outer screen now I keep getting this black smudge on my screen do I have to remove the lcd or do I use loca
这个答案有帮助吗?
得分 1
9条评论:
depends on "the smudge", post an image and let us see what you see.
完成的
https://dl.dropboxusercontent.com/u/5441...
Here's a link to the images and no its not water don't know what it is when I go to remove everything to remove the screen it goes away
完成的
"when I go to remove everything to remove the screen it goes away" what exactly do you mean by the? right now it looks like air trapped between the digitizer and/or LCD.
完成的
When I go to seperate the frame from the back piece to get to the screen I guess it could be air
完成的
It does look like it creates a bubble underneath,
完成的
显示更多的4条评论
添加一条评论
Thank You :)
One more question: Do you recommend exchange by my self, or go truth an specialist. looks not complicated but I do know nothing about cellphones. looks like is just the glass screen broken but since this was broken because I press with the trunk of my car:( I do know if can be there another damage.
The other hand, I find a different options to by a screen replacement, since screen glass to digitizer and complete screen digitizer assembly? could be the last one a best option...I appreciate any tip to do it or not risk. Because I really want back my cellphone for personal reasons.
Thank You.
这个答案有帮助吗?
得分 0
1条评论:
Replacing the LCD will not affect your memory.
完成的
添加一条评论
添加你的答案
alacranking 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 19
总计 7,016
