跳转到主内容
加入维修社区 - 创建账户
A 10.1 inch Samsung tablet computer with a 1.4 GHz processor, 1280x800 pixel LCD, and 149 ppi multi-touch display. The model number of the device is GT-N8013ZW. Released August 2012, repair of this device is straightforward.
Why does my tablet respond to S-Pen but not my fingers?
I just finished repairing one problem I had, where the screen gets all discolored. Once I closed it up and started it, it would not respond to my touch, nothing. I tried the S-Pen and it worked fine. Does anyone know what could have caused this? I reopened it and check the ribbon connections, the only one that looks questionable was the central ribbon cable. Now, I don't know much about electronics, but I noticed that on all the other connectors for the ribbon cables, there was a locking switch. I don't think the connection this ribbon cable has one, and I fear that out of ignorance I may have damaged the connector attempting to flip the non-existent locking mechanism. I believe this to be the cable that connects to the front screen (Not the LCD), and is what is used to communicate the touch input. So I think this is where my problem lies. Can someone enlighten me with their perspective on this issue? I think it must be a damaged connector (requiring me to get a replacement motherboard), the ribbon cable isn't fully connected (tried my best), or something else I am not seeing. Hopefully it is fixable, I would hate to have to scrap a tablet just after 5 months of use. Could it possibly be a broken or damaged digitizer? I have dropped it a few times.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 33
8条评论
Hi it is a commen problem and I don't understand that Samsung is not having a better product. It make you think if it was worth the money.
完成的
i have note4 edge its option and back space sensors are not working while using only it works with the pen can anyone tell me how to fix this problem ..../
完成的
I have note edge it is not walking by finger only by spen
完成的
Sometimes when the phone does not work using your finger but the S pen is, and you have tried to go to your settings to disable the S pen function then you should visit the nearest service center for assistance, it could probably be a software issue .
完成的
I had the same issue, I had to call my phone carrier, back up and factory reset my phone and no luck so they replaced the phone. It is a software issue.
完成的
显示更多的3条评论
添加一条评论
12个答案
最有帮助的答案
Brett Daniels, both situation are a possibility. The connector could fail to properly seat the cable, or it could simply be a digitizer failure. Post an image off your connector on here so we might be able to see any damage. If nothing else, you might be thinking about getting the digitizer replaced. Check on here to see if that is something that you would want to tackle. Hope this helps, good luck.
这个答案有帮助吗?
得分 5
7条评论:
Alright, I think Ill order a replacement digitizer and give it a shot. For connecting the digitizer's ribbon cable, what is the best teqchique? I found it very hard to get the cable in fully, hard to use tweezers and it felt like abuse, wish it's connector had a locking mechanism like the others. The cost of a new digitizer is around $50, what is the cost of a new motherboard? The digitizer seems liek it would be easier to replace, I feel replacing the motherboard might cause some data loss of some sort.
完成的
If you replace the motherboard, you will lose all your data. The data is sorted on the memory which is hardwired via IC to the board. As in price, it is another one of those where the motherboard is hard to find and will most likely be more than a new Note.
完成的
k, purchased a new digitizer, once it gets here ill hook it up. Any suggestions for techniques on connecting the digitizer's ribbon cable?
完成的
Not really anything other than double jointed, long, skinny fingers and lots of patience ;) use long toothless tweezers to try to get the cable connected.
完成的
Alright thanks, just noticed my left speaker is not working, checked the inside and looks like the speaker's ribbon cable is completely broken, is it possible to order a pair of replacement speakers? I couldn't find any just by looking around
完成的
显示更多的2条评论
添加一条评论
Just a thought. This seems rather simple, but there is a function of the tablet that can ignore the fingers while the s pen is nearby. If you tried to touch it with your finger while holding the s pen in the same hand, it would not work with this setting in place.
-David
这个答案有帮助吗?
得分 2
1条评论:
where can I change this setting.
完成的
添加一条评论
Dear All
The problem is too easy...... just disassemble the back cover of the galaxy note then check all connection "specially the one near to the power plug" it must be fitted to the connection line ten assemble it again it will work "in shaa alla".
thanks
这个答案有帮助吗?
得分 2
3条评论:
No that's not it. The problem was the digitizer. Better luck next time bud. Was fixed by replacing the broken digitizer.
完成的
I'm David. Another David. I just purchased the galaxy note 5 a few days ago a couple of days ago the screen began to intermittently, temporarily lose its capacitance where sensing my finger is concerned.
It has ceased picking up my finger all together, just yesterday. The connector APPEARS to be fine so I'm guessing that it may be the digitizer.
完成的
Same problem but my screen freaked out
完成的
添加一条评论
What I discovered after encountering this issue is that if my folio cover is folded such that the magnetic edge is in contact with the RHS of the tablet I get issues with touch, but not pen input. If I fold it such that the magnetic edge is on the LHS (or not near the RHS) there is no problem. It's obviously got something to do with the sleep wake function with the folio cover.
这个答案有帮助吗?
得分 2
7条评论:
Yup, that was the problem for me. Thank you much for pointing that out!
完成的
Yes!I just removed my cover (magnetic) and the problem solved without restart !
完成的
also, i noticed if this doesn't work, if you simply rest two fingers on the screen for a second or two,it will start working again. please try this before taking your phone apart! i'm celebrating how it worked for me! good luck folks!
完成的
What do you mean magnet edge? I am having the same problem on my galaxy note but don't know exactly what the magnet you're talking about is or where.
完成的
I removed the cover and it worked
完成的
显示更多的2条评论
添加一条评论
My wife's galaxy note had the same problem, nothing else seemed to work until we removed the cover! apparently the same problem that Grobolo was experiencing . Who would've thought. and this after she had been using the same cover, put on the same way, for a long time without problems until she updated it. grrrrrr.
这个答案有帮助吗?
得分 2
3条评论:
Did this work for the note 5 plz I need to know . I hear rattling and my screen flipped out and now the tuch of my finger does not work but the s-pen does, I went through and cleared the cash partition so I need to know before I take it apart again......
完成的
Thanks! This worked for me! I was about to chuck my phone at the %#*@ wall lol.
完成的
Rancio, you are right!
完成的
添加一条评论
I just want to thank all the contributors on this thread. This morning, I, too, dropped my tablet (onto a carpeted floor) and ended up with a black screen although I could tell it was still working otherwise. I was upset since I've only had it a few weeks and since I bought it used, well... There went my major investment of Christmas money.
But, with a couple of YouTube videos, and all the suggestions I saw here and other forums where people really do try to help each other, I managed to fix it. Getting the back off was a trial, though and nerve-wracking for an only modestly technical person.
The first time round, I got the screen working but couldn't do any finger swipes, and the S-Pen was intermittent. So off came the back again. This time I made SURE the two cables at the very top (including what I presume is the digitizer) were really and truly aligned with the white guidelines next to the sockets. The tolerances are amazingly tight (every millimeter counts).
这个答案有帮助吗?
得分 2
添加一条评论
If you are having the same problem as the OP (ie the touchscreen works with the S-Pen but not your fingers), don't take your phone apart. Just go to application manager (in your settings) - find Google Play Store and uninstall all the updates. Then restart your phone and the touchscreen will work again.
If it doesn't (but it will in 99% of cases), uninstall updates for other Google / Samsung apps.
Then restart the phone.
这个答案有帮助吗?
得分 1
添加一条评论
Hi, I replaced my screen too and had the same issue. Touch is controlled by the top layer of the screen. http://www.ebay.de/itm/like/161955166515...
It´s very likely that it´s connecting ribbon isn´t connected properly.
I have taken off the cover, unpluged the battery, unfastened and pulled out the ribbon, put it in again properly and tight, fastened it by the clip, rehooked the battery back in, tested it and as it worked, put the cover back on.
Hope your problem can be resolved. :)
这个答案有帮助吗?
得分 1
添加一条评论
Just dial *#2663# and that will recalibrate your touch screen. ....i can believe no one posted the real answer to this . Don't take your screens apart guys.....just dial the number string
这个答案有帮助吗?
得分 1
2条评论:
Dial *#2663# ....this recalibrates the touch screen
完成的
Go to your dialer and press *#2663# and update all the touch firmwares.
完成的
添加一条评论
I just changed my screen and digitizer together because of the same issue (water damage). I recommend changing both the screen and digitizer assembly together because just replacing the digitizer can be very tricky. Watch this video for reference
http://youtu.be/A1ntOfJS_1c?list=UUdCZPl...
I bought the screen and digitizer for $185 and it took me a total of 45 mins to 1 hr to replace. Bought the assembly off of ebay
http://www.ebay.com/sch/i.html?_from=R40...
NOTE: I had to re- bend the home button spring clips (on back of main board) on mine and make sure that all the flex cables snapped into the main board because this results in the phone malfunctioning (aka the finger swiping not working on the new screen but S-Pen worked). I had to unclip and reclip the screen cable 3 times before I got it in correct.
TRUST ME IT WASN'T HARD JUST TAKES PATIENCE
这个答案有帮助吗?
得分 0
添加一条评论
Settings>device or controls>S-pen>Disable pen detection
这个答案有帮助吗?
得分 0
1条评论:
Go to
Setting / Controls / S Pen /
then disable "Attach/detach vibration"
完成的
添加一条评论
You have only one solution,
1- close your mobile.
2 remove the battery.
3- open the cover by remove all scraws and clean from inside then after that fix the cover and keep your battery then check it.
This is issue happens with me yesterday and I solved it.
thanks
eng. Issa
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brett Daniels 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 36
过去 30 天: 193
总计 146,756
