跳转到主内容
奥林巴斯数码相机的维修指南和支持。
230 个问题 查看全部
Is there a way I can turn the Olympus E-P3 screen on/off?
One day the screen was black after i switched it on. The touch functions still works, i can take pictures touching the screen.
I can use the VF-1 optical viewfinder and it works as it should.
So everything works, except that the screen is black.
Is there a function i've missed where you can turn the screen on/off? (i've read the manual and can't find anything about this)
Can it be a loose cable as the touch is working, but not the image?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
umagon1337, it does not appears as if the LCD can be turned off on purpose. The E-P3 uses two separate ribbon cables on the display, so it is possible that you are having trouble with the LCD ribbon while the digitizer still works. At this point I suggest that you disassemble your camera and check for any loose connection. Take a look at the LCD, it appears as if you are needing a new one.
这个答案有帮助吗?
得分 1
2条评论:
Thank you for your answer. I guess i will buy the right tools and open it up as you say and hope it is just the one ribbon cable.
完成的
Sounds like a good plan, I hope it will work out for you. Thank you for accepting my answer.
完成的
添加一条评论
添加你的答案
umagon1337 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 267
