跳转到主内容
The second iteration of Samsung Galaxy Tab tablet computers with a 7.0-inch screen. Model numbers: GT-P3105, GT-P3100, and GT-P3105.
125 个问题 查看全部
My screen is all wonky?
While browsing Instagram, I went to my friend's page. All of a sudden, the device froze. I pressed the power button to turn it off, then tried to turn it back on. It didn't turn on, but I could faintly see an outline of the items I had been looking at. When I hold the power button for a moment, it flashes, but goes back to black. What does that mean?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
If you can faintly see the outline of your desktop, just not lit, that means that your backlight is out. It could be the backlight on the LCD or the backlight circuitry on the logic board. I'd start by resetting the device. If that does not help, you may have to replace the LCD. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
Try pressing power button for ~30seconds to reset device.
Also, I had a brightness software installed that dims brightness to zero, it´s a low chance, but maby consider a software setting brightness to zero too.
这个答案有帮助吗?
得分 0
添加一条评论
Charge it. Power supply failure perhaps. Mine acted like that ...new power supply fixed it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jake 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 5
总计 1,898
