跳转到主内容
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
Can't get a network connection?
I am unable to access Facebook, Google, Voicemail....anything that requires a network connection. Seems like my phone is missing something it needs to connect.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
jamazaad9@gmail.com
完成的
添加一条评论
4个答案
已选择的解决方案
I recommend testing your SIM card in a friend's phone to make sure that the problem isn't with the card itself, or with your account on the provider side of things. If you do this and confirm that your hardware is at fault, it will be very difficult to troubleshoot without some knowledge of electronics and antennas in general. First, check a guide to diassemble properly. This model should have a plastic antenna near the bottom of the phone, and two shiny, gold, springy contacts on the motherboard which make contact with the underside of the antenna inside the phone. Cleaning and/or resoldering usually will do the trick. This type of antenna rarely needs to be replaced because it is essentially just a piece of wire printed onto a piece of plastic. Poor connection is usually the culprit.
Also keep in mind, sometimes software glitches can result in "No Service" indications but it is uncommon in your particular model. If you can do a software update via WiFi and you have the same issue afterward, you can pretty much rule this possibility out.
这个答案有帮助吗?
得分 2
2条评论:
Yh it is the software glitch
完成的
Please can you help me
完成的
添加一条评论
check to make sure mobile data is enabled in your settings
这个答案有帮助吗?
得分 0
添加一条评论
i cant accessmobile network for calls.
这个答案有帮助吗?
得分 0
添加一条评论
Well, first check your wifi settings of your phone also your router settings because what happens sometimes you get disconnected due to certain updates and have to reconnect with your wifi and if you have done these things then you can contact us personally at https://techyuga.com/kolkata/
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kathleen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 8,778
