跳转到主内容
索尼所制造的台式机。
open the Sony Vaio VGC-JS to expand the hard disk
Sony VGC-JS All-in-One Model PCG-2P1M, hard disk failure
All-in-one PC solved all the screws, will not open.
How can I get the hard drive?
Urgently need help. Thank you!
Thanks for the drawing.
I can not release the stand. Is there a trick?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
http://www.youtube.com/watch?v=Hl0QI69xn...
This is the solution!
All screws on the back and bottom. Then solve the edge gently with a small object.
Thanks for the video!
完成的
添加一条评论
1个答案
已选择的解决方案
Mirjam Graf, this is a bit of a beast to open. Check the attached image, all the parts that need to be removed are highlighted. Here is a okay video that might be helpful to you too.
Hope this helps, good luck.
这个答案有帮助吗?
得分 2
1条评论:
I need more help, thank´s...
完成的
添加一条评论
添加你的答案
Mirjam Graf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 3,785
