跳转到主内容
作为任天堂 Game Boy Advance 的一款升级产品,Game Boy Advance SP 于 2004 年 3 月 23 日在北美地区发布,它采用了方形机身结构和翻盖式设计。
Why won't my GBA SP charge?
So here's my issue. Whenever I try to charge the device, the indicator light turns on for a couple seconds, then turns back off. I've noticed that sometimes if I bend the charging cable a certain way, it might start charging. But, it will not keep charging if I let go of it. Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Jesse M, sounds to me like you already figured it out:-) "if I bend the charging cable a certain way, it might start charging. " I would start with a new charger and a new battery. If that does not work, I would then replace the charging jack. Hope this helps, good luck
这个答案有帮助吗?
得分 3
添加一条评论
probably the circuit board
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jesse M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 5,593
