Why is my music still playing out loud with headphones in?
When i plug my headphones in my phone, the music plays out loud. I don't know why. I changed headphones but that wasn't the solution
Rakeria Washington, sounds like it is the actual headphone jack. It should turn off the circuit to your speaker when it detects that the headphones are plugged in. If you give us the model of your phone, we might be able to help you with the replacement as well. Hope this helps, good luck.
这个答案有帮助吗?
I have a lg fortune and only one ear is working which is the left every now and then the right comes back on canny help me fix it please
Also I'm using Bluetooth headphoned
@passionate if you are using a bluetooth headset check your crossover cable. From left to right or vice versa.
Hey! I seem to have the same issue however I'm using a different model? I believe it's called Huawei Honor 8 lite.
Hi,
I am facing the same issue with my Android OPPO F3 plus. Can anyone please me with the issue. And headphone are compatible with this phone because I was using the same headphones in past
This happened on my Moto X and it was because lint was inside the headphone jack preventing the headphones from making a solid connection. Power down the phone and use a wooden or plastic toothpick and make sure there is nothing jammed inside the headphone jack.
这个答案有帮助吗?
I have a brand new Samsung galaxy j5 2017. It came with headphones in the box. Nothing is jammed in the jack. All bluetooth etc is switched off. I've rebooted the phone several times and started it with headphones in and headphones out. The phone will not play music through headphones. Just blasts it from the phone speakers....help....sooooo frustrated!
It works thanks moto e5 play
Thnx man you're a god!!! :)
Restart your phone. i came here looking for answers. i use a kyocera hydro vibe and the headpjone outlet didn't want to work. but after i restarted it it worked fine.
这个答案有帮助吗?
Answer was sooo very helpful I did not know what to do I tried your solution and it worked perfectly. Very great advice.
Worked for me too
I have a similar problem only when I plug my head phones in on my new lg stylo 3 from boost mobile it keeps flashing between listening and my music or game or whatever else I was trying to use them for. Very annoyi ng
Restarting does not solve the problem. I need to know how to set the settings to make the music come out of the headphones.
Don't believe it has to do with settings. If you have a newer phone (splash proof) your headphones must be gold tipped to improve conductivity. My son is an auto mechanic and realized my phone had a splash proof coating so I switched to gold tips and it works beautifully
Hello. It might not be the actual headphones. More than likely there is a setting on your phone that can direct the sound to your headphones. It happens a lot to me, but I change the settings to "headphones" from "internal speaker" and it works every time. I hope this helps.
这个答案有帮助吗?
how do you do that? i have a Zte Maven
I Have A Samsung Galaxy Mega 2, How Do I Change Mines!? I Don't Know Where To Go 2 Change It!
How do you change the settings to "headphones" from "internal speaker" ? Step by Step. What settings?
When I go to the headphones section in my settings it always says unfortunately audio settings has stopped and it never works what shall I do to fix it cos my headphones still play out loud
I have a solution that worked for me: what I did was plugged the headphones in but not all the way put them in untill the last that makes the click and twist them a little and you should hear it only on one side and then you push them the rest of the way
这个答案有帮助吗?
Thankyou sooo much this worked for me
My son and daughter got the exactsame tablet and exact same headphones… My daughter can plug in headphones and it works perfectly fine. My son plugs in headphones and you hear it in the headphones and the tablet speaker… Help
这个答案有帮助吗?
How did you get it sorted after all as my kids have got same tablet our sons wont come up with headphone
I had this problem. I got a cotton but cleaned it out blew down the hole and also my phone was due a system update, this was a galaxy s6 edge. Then I left it over night and it worked the next morning. If your phone needs an update to that but defiantly attempt cleaning it it can work
这个答案有帮助吗?
Do you think this could work for an iPhone 7?
I don't know.I have a Motorola phone!
If your headphones or earphones are playing out loud after you've plugged them in there might me a broken piece inside where the earphones go that's why mines kept playing out loud l. You might need a new phone or get it fix the part that was broken my dad kept outing it back into place with a needle but it would work then pause and play out loud. You might need a new phone. Hope this works
这个答案有帮助吗?
I think a piece of metal has broken off the end of my other earbuds in the headphones jack. I can't afford a new phone. My phone has to last me a long time. I only had my phone for about 2-3 months. I can't buy a new one. Is there anyway I can just go get it fixed? Maybe at the mall or Walmart?
You might be right this phone is a hamedoun from my Mom to my older brother Daniel to me.Thanks Kennedy!
I have an older version of Sony Xperia and the music plays outloud with my headphones plugged in but once I switched headphones there wasn't a problem but I can't find the setting that I accidentally switched that made my phone unresponsive to my headphones. Normally a "headphones plugged in" message pops up but now it doesn't.
这个答案有帮助吗?
I've got the Samsung S9 with the same issue. It SUX!
Whatever it is, it has nothing to do with hardware. It’s a settings issue and no one seems to know how to communicate the way to fix it.
这个答案有帮助吗?
Have you tried gold tipped headphones? If your phone has a splash proof coating the silver tipped headphones don't work. Just borrow someone's headphones and try it. It won't cost you anything. Most phones don't even have software settings for headphones.
I have a moto E4 it just plays out loud when I plug it in. And sometimes when I plug it in the volume automatically goes all the way up. What's wrong?
这个答案有帮助吗?
How do I make the music play through my earpiece . It says connected but it's still playing out loud
How do I make the music play through my earpiece . It says connected but it's still playing out loud I have a tablet
If you just recently purchased your phone it may have a splash proof plastic coating which requires gold tipped headphones which has improved conductivity. It solved my problem!
这个答案有帮助吗?
I’m having the same problem but with Bluetooth headphones
the way this works…..the headphone jack has a switch in it. When you plug the HF in, it opens the switch as long as it goes all the way in.
That either disconnects the speakers directly, or signals the circuit to turn off the speakers.
Therefore, there is no issue with the HF if they work. If the speakers continue to work then either the jack is defective if it is a direct switch, or the cutoff circuit is defective or a setting is wrong.
If there is anything in the plug, like hair or fuzz, that would cause the HF not to work. It would likely turn off the speakers since the switch would be activated if the plug went all the way in.
这个答案有帮助吗?
I can not understand were by both headphones and the phone it's self are both playing
sound coming from speaker and earphone (wired & wireless both) at the same time (motorola g60)
solution i found for that is & it worked for me is switch the phone to safe mode find a way to do that its easy and then connect earphones (both type) and play music , it worked and then switch to normal mode and connect earphones and it fixed it
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 34
过去 30 天: 133
总计 371,212
17条评论
I got a flash light and looked in my headphone jack and there's nothing inside of it. And I looked on settings and I dident find anything I wonder if I need to restore it
由 Alien weed detective 完成的
My issue with my LG is my head phones broke off into my phone if i dont have a Bluetooth how do i play music outloud on my phone i can't find a speaker phone botton unless im making a phone call thats the only time i can here anything on speaker
由 jhomer6973 完成的
I'm having same issue with my Infinix Hot S. My music plays out loud when I plug in my earphone. Pls I need solution urgently.
由 emekaharry90 完成的
Iplug the headphones into the jack, the music plays thorough the internal speaker. How do I get music to come out of the headphones?
由 chanceflannery 完成的
I tried all of this. My phone works with all earbuds except my apple ones, but the apple ones work fine on my laptop.
由 Kermits croissant 完成的
显示更多的12条评论
