跳转到主内容
Pavilion dv1000, Intel Pentium M 1.5GHz, 512MB RAM, 80GB hard drive
20 个问题 查看全部
No display after start up
After windows starts to lode and go to main screen the screen remains black. I have hooked it up to another screen but the same thing happens. I have ran a hard drive test on it and it has a #1-07 Fail. It will not start in safe mode either. I do not have any back up disk or recovery disk. What do I need to do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Kim, 1-07 Fail indicates that the hdd is failing/failed. Try to setup your boot order in your BIOS to your optical drive and see if you can run your computer with a Live CD Linux version (I prefer Puppy Linux) and see if it lets you access your hard drive. If it does, back up your files and be prepared to replace the drive. Not sure about your OS you could try and see if you get a replacement recovery disk through HP otherwise you could purchase a OS disk retail or run any one of the free Linux versions. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kim 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 11
总计 245
