跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Small component broken from the logic board
Some of the small components of the logic board of an iPhone 4S are gone. It gives problems during charging. They are pointed with an arrow on the picture. What are those? Can I solve this problem by bridge the contact points? Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Gauthier Top, I marked the components in numerical order. They are a follows.
1. C293 100PF 5% 16 V NP0-C0G Capacitor
2. R153 0.00 0% 1/32W Resistor
part of BATTERY_NTC circuit
3. R61 0.00 0% 1/32W Resistor
4. C300 100PF 5% 16 V NP0-C0G Capacitor
part of BATTERY_SWI circuit
You should get away by bridging the resistors, but I would not bridge the caps. Hope this helps, good luck.
这个答案有帮助吗?
得分 4
5条评论:
It worked. Thank you very much!
完成的
you are welcome. Thanks for accepting my answer.
完成的
where can i get those Capacitor and Resistor
完成的
@Rahul BJ, depends on where you are located. Mouser.com Digikey.com and many other places should have those.
完成的
Yes they are. The 0 value resistors are actually just jumpers.
完成的
添加一条评论
添加你的答案
Gauthier 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 7,718
