跳转到主内容
Repair guides for the variations of the Compaq Presario CQ62 laptop. This brand was manufactured from 1993 to 2013, and was owned by HP from 2002 to 2013.
51 个问题 查看全部
No power acknowledged by Laptop? Neither battery nor external power?
Defective Screen(cracked) was replaced. Initially worked but after reaching home shows no signs of leda blinling even after connecting external power suppply which was checked & is perfectly working. Now due to no power shown it obviously is in no condition to start.
Where do I start trouble shooting?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
Sudeep Chatterjee, I'd start by double checking the work you did. Make sure that all the cables are properly connected. Check the DC jack to make sure it is properly seated. Then check the AC adapter for proper voltage. If it does have the proper voltage, plug it in and measure the voltage on the DC jack of your logic board, to see if it does work. It seems like you have a main power problem which occurred after your repair, so start with that first.
这个答案有帮助吗?
得分 0
添加一条评论
Hi Sudeep Chatterjee,
Just to be sure i would make a hardware reset.. I have had similar issue where either charged battery or AC-adapter is accepted and Laptop will not start.
Does Caps Lock flash? and do Power button flash in a pattern?
This did help me to get it started.
Unplug the power cord --> Remove the battery --> Hold the power button for 60
seconds --> Connect the power supply then try to switch ON the laptop and later
put the battery back into the laptop.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sudeep Chatterjee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 1,512
