跳转到主内容
加入维修社区 - 创建账户
Nexus S 是由 Google 与三星共同研发的智能手机,也是首款采用 Android 2.3 “姜饼”操作系统的智能手机。
Nexus S Power Button Not Working
Hi all,
My Nexus S dropped into water the other day. After it's dried, I managed to boot it up by plugging in the power cable. Soon I realized the power button had stopped working. Other than that the phone seemed to work fine.
What should I do to get the phone fixed? Any ideas what parts I should replace and where can I find them? Thank you!
Jason
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Hi Jason,
I trust that you did a great job in drying the phone. I would make sure that the phone is completely dry inside. If the power button did not experience a physical damage, its malfunction could be related to water inside. And besides that, corrosion can occur.
I would open the phone and disassemble it as good as you can. Let every part dry. Also, take the motherboard in particular and lay it into isopropyl alcohol (90%). Let it stay there for about 10 minutes before you take it out of it. Then let it dry for about 2 days (e.g. next to a warm source like an air conditioning) before you put it back again.
Sure, water damage could have created an immediate shortcut. However, by following the steps above we might be able to solve the issue or - at least - are able to go from there.
Steffen
这个答案有帮助吗?
得分 3
1条评论:
Okay so what do i do if my power button just stops working?? never been dropped in water, never been dropped.. One morning my power button just started getting very sensitive then my phone tried to reboot and i haven't been able to turn it on since then. i've pulled the phone apart and there is no corrosion and no water damage.. Any help???
由完成的
添加一条评论
Réchauffement de réparation Samsung téléphone
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jason Lin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 20
总计 4,746
