跳转到主内容
加入维修社区 - 创建账户
Kinect 是专为 Xbox 360 设计的一款游戏外设,允许用户通过肢体动作和语言来控制游戏主机。
kinect not leveling C0051209
the Kinect turns on but wont move, I tried to use tuner in settings but to no avail same out come. it only says "C0051209 not level" do you have advice or parts for this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Hallo everybody,
I have got the same Problem. When i lift up my kinetic Sensor on the right side. My kinetic Sensor is still working. I Hope someone kann help us. Greetings Stefan
完成的
添加一条评论
1个答案
已选择的解决方案
Follow the steps below if the light on your sensor is red and you receive the following message on your screen:
Error: The Kinect Sensor is not level (C0051209)
Place the sensor on a level surface and try again.
Here’s what to do to fix this problem:
Turn off your Xbox 360 console.
Make sure the Kinect sensor is positioned on a flat, level surface.
Turn your console on to see if the problem still occurs.
This error can also occur if your sensor is very hot or cold. In this case, wait for the sensor to reach room temperature (approximately 70 °F or 21 °C), and then try using the sensor again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
anthony califano 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 2,378
