跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 个问题 查看全部
How to install LVDS connector in Logic board?
it is fustrating as I have spent for a new LCD panel to know later that it is the connector itself in the logic board that has the problem all this time. I tried to clean it and since it is really small and has got 30 pins I guess, it is very hard to see. Anyway while I tried to put some force on it while LDVS cable is connected etc it finally came to pieces and now the connector is gone fron the logic board. I thought and still think I have to change the logic board butwhen I found 30 pins connector in ebay and other online stores my hopes are high. Is this is the correct part and how to fix? Anybody tried this method before? Please help me and confirm thepart I saw os the correct one. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
4条评论
You did not show us the part you have seen:-)
完成的
i think i might be in the same boat. the only thing that looks like a fuse is labeled
110F
24V
i get continuity on it so i don't think its blown...
完成的
same problem here, broken connector
anybody knows how do this service ?
完成的
@youtrytofixit, you mean to solder a new connector to the board?
完成的
添加一条评论
5个答案
已选择的解决方案
anr193, first thing that you have to do is to let us know exactly which computer you have. Please post the last three digits of your computer or at least the numbers of your logic board. Second, the connector is of course soldered to the board. Unless you have experience with soldering very small pieces to a logic board, I would suggest you find someone that can do it. Yes, the connectors are available, and are not even expensive, but this work is not easily done. The connector is a I-pex Connector 20474-030e-11 and is available at places like this and others. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
2条评论:
Thank you for your response. I have Macbook unibody A1278 2008 2ghz version. You can search for the connector in ebay when searching for Macbook A1278 LVDS connector. (I hope I am correct)..if you need more info plz let me know. Thanks
完成的
anr193, click on the blue "like this" in my answer. It will show you the right connector for your computer. It is a I-pex Connector 20474-030e-11
完成的
添加一条评论
@Nathan Reeves: the backlight fuse should be the brown IC with a white P on it.
这个答案有帮助吗?
得分 1
添加一条评论
You need a hot air station to remove the faulty I-pex connector but you can't use the hot air station to install the new connector (connector plastic part would melt). It must be installed with a solder iron and only can be done by a skilled tech.
这个答案有帮助吗?
得分 1
3条评论:
Since you know about this do you have a logic board that you coukd show us how to do it?? Since the purpose of this site is to learn so teach us dumbs andmake us skilled techs. ANnyone??
完成的
If you do not know how to solder, I urge you to obtain a few old circuit boards of any kind and practice how to solder the surface mounted devices components. This is not a skill that can be taught by theory alone. Take a look at a few YouTube videos like this one to get a good understanding of what is involved.
完成的
I agree with oldturkey03, it take practice to do such a delicate job. It's not only to solder the connector in place but the work surface (pads) must be prepared adequately before the connector is soldered on the pads. Amount of solder paste applied to the pads, use of liquid flux, use of the right solder iron tip, use of a microscope are all important factors to succeed in this kind of work. Better buy the connector and find a tech to install it.
完成的
添加一条评论
Hot air station can also be used to install the new connector. That is basically how it was installed in the factory, thus connectors like this are heat resistant. Too much heat will still destroy them. In practice pre-heater is needed in addition of hot air station for properly reworking such connector. Pre-heater allows lower temperatures to be used in hot air station.
这个答案有帮助吗?
得分 0
添加一条评论
hi,
see this youtube video for a detailed soldering tutorial. doesn't look easy at all:
https://www.youtube.com/watch?v=HtTsthC-...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
anr193 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 4,186
