跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
Stuck up with apple logo on screen
I have Old 8GB 2g iPhone, when i am making it on it is stuck on Apple Logo its keeps blinking and when i am connecting using the USB data Cable it is not detecting, Also there is data inside it which is very imp to me can any one help on this will be great for me and a lot of thanks in advance on any response
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
6个答案
已选择的解决方案
You will have to force your device into recovery mode by holding down the Home button while you plug the USB cable into your computer. Follow the prompts in iTunes to restore the firmware. There is no way to recover your data, sorry.
这个答案有帮助吗?
得分 1
添加一条评论
I think that it is possible to recover the data from your iphone if you have done a backup with itunes before it went dead on you. Of course it will only get the data that was on your phone prior to the backup. Here is a link that I had to use once before myself....Shows the importance of regular backups;does it not?
http://www.gadgetsdna.com/how-to-recover...
http://menoob.com/iphone/how-to-recover-...
Hope this will help you a bit with the data. I agree with Bushing in regards to the phone itself. Hope that these answer will help you and best of luck.
这个答案有帮助吗?
得分 0
添加一条评论
I will help you to solve your problem, don't worry just follow as I say.
1. Firstly it is not a big problem just do as I say.
2. Connect your device to the PC and then launch the iTunes software.
3. And then go for the option of 'Restore' in that iTunes.
But if your device doesn't respond to it.
4. Then try to update the iTunes software to latest version.
And using windows OS means you need to uninstall the whole previous version of software and need to download and install the latest version of it.
5. And if you are having the third party apps such as Antivirus and etc are installed then it will object your phone to respond to iTunes. So you need to update your iOS software at any cost, which is the only way to
这个答案有帮助吗?
得分 0
添加一条评论
but my iphone is blinking with apple logo, i know the recovery procedure but i dont wanna lose my data:( what should i do?
这个答案有帮助吗?
得分 0
1条评论:
That's why keeping a backup of important information is always recommended. This may work - i've not tried it, just did a Google on recover iphone data and it turned up. And - For future reference you posted a Comment in the place where only Answers belong. Please use the add comment link to the appropriate Answer or update your O.Q..
完成的
添加一条评论
As we know, after upgrading the iOS, jailbreaking, or restoring your iPhone from iTunes, you may encounter some problems like that your iPhone can be started normally. It stuck at the Apple logo screen, or in an endless loop so that you can't move forward. Now, this tutorial shows you how to get your problems fixed with one click. Moreover, you won't lose your iPhone data. Please keep reading this article.
iPhone stuck on the Apple logo screen. Fix it with 1 click.
这个答案有帮助吗?
得分 0
添加一条评论
Why are my contacts not syncing correctly between iPhones and iMac?
How do I put my iPhone 3G in DFU Mode?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sagar 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 4,181
