跳转到主内容
加入维修社区 - 创建账户
Connection Port is damaged
Hi; I have a damaged port, the inside pin has a slight piece missing off it, enough that it won't recoginize the device on the computer. Although it will charge on my Ipod/Boombox charger! Is this too complicated a fix or too exspensive, I only paid $50.00 for it two months ago.
Thanks Betty
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
jackbird, you will have to disassemble your iPod. That is most certainly a PITA. Follow this guide to get that done. Then you will have to find a proper connector, which can be quite a chore as well. After that you will have top desolder and then resolder the new adapter. Remember that there are 30 some connections that need to be soldered. You will need a good soldering iron, or a rework station. So is it complicated, yes but doable. Is it easy, absolutely not. You may want to do a Google search and see if you find someone that is willing to do that type of repair for you, or replace the board itself. Hope this helps, good luck
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jackbird 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 251
