跳转到主内容
Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
175 个问题 查看全部
Where is the backlight located?
In the questions/answers some posts indicate that the backlight is part of the display/touchscreen assembly, while others indicate that it is located on the logic board.
My son washed his nano in the pocket of his jeans like so many others have. After drying it in a low temp oven it works fine except that the backlight is out. You can still see the screen if you hold it under a bright light.
I don't need a new screen, unless that is the only way to get a new backlight. I don't see any mention of backlight in either the repair manual or the parts page for the display module. Can anyone confirm if the backlight is part of the display assembly or the logic board (or something else) in the ipod nano 6th generation?
ifixit, it would be great if you could update the repair manual to include this info. I see that others have the same question/problem.
thanks,
--steve
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Steve Ravet, the backlight consist of more than one part. Consider this simplified analogy. The Backlight (lightbulb) is in the screen assembly, the light switch is a coil on the logic board and the power supply, backlight IC is on the logic board as well. I've found that I have had logic board issue with 90% of the water damaged Nano's, but since there is not a whole lot of information about the Nano's circuitry, I would start with the display first, since it is cheaper and easier, but not easy. Of course, you also want to make sure that you clean all the parts properly with isopropyl alcohol, and do not forget to clean all the connectors and cable ends to make sure that you are not running into any corrosion issues
这个答案有帮助吗?
得分 1
1条评论:
I thought it was LED backlight, but it sounds like you're describing EL instead?
完成的
添加一条评论
when I plug in my laptop to charge it,the screen becomes bright when I unplug it after its charged,it get darker,please help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Steve Ravet 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,927
