跳转到主内容
加入维修社区 - 创建账户
适用于配备 GSM 3G 蜂窝网络(AT&T)的第二代 Apple iPad 的维修指南、拆解和故障排除信息,有 16、32 或 64 GB 存储容量可选。采用双核处理器。于 2011 年 3 月发布。通过型号 A1396 进行识别。维修时需要使用加热工具并小心撬开。
Sim card not recognized
Hi. Some day ago my ipad2 wifi+3G (european) stopped to recognize the sim card. I tried everything, iTunes reset, dfu reset, removing sim card, activating and deactivating airplane mode. Nothing...the sim card is ok on my phone so seems to be a hardware related issue and I'm out of warranty since march 1st (%^%%!!).
There's something I can do myself? Thanks!!
Michele
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
It happened the same to me on my ipad 2 3g (and the warranty expired two months ago!!!!!!!!! ) The wifi mode is still working but the ipad is not recognizing the SIM card and it appears "No SIM".
Apple is not settling it and they offer me to change the whole ipad, paying like 270€! for another ipad 2 (not new, but repaired from others..).
I'm so angry!!!!!!!
由完成的 分享
Yes it work for me thank you
由完成的 分享
添加一条评论
4个答案
最有帮助的答案
There is a solution to the fix but it involves taking it apart and soldering. Not sure if you have the skills
http://i1266.photobucket.com/albums/jj52...
这个答案有帮助吗?
得分 2
5条评论:
Hi YoloRepair, please post the repair for this so long.
由完成的 分享
http://imageshack.us/photo/my-images/835...
Look at the picture and check those pins for continuity using a multimeter. Once you find the line that's broken you have to solder a jumper wire directly to the test point. Make sure you isolate the wire so that it doesn't short at all.
From what I've seen the red line is usually broken but check them all to be sure.
由完成的 分享
Hi YoloRepair ca,
I tried clicking the link to your photo but it doesn't work. Little help, please.
由完成的 分享
Ryan can you email me - email should be in my profile. Been having some issues with ifixit lately.
由完成的 分享
I'm getting no luck lately with ipad's. I have now encountered this NO SIM issue on an iPad 2. Replaced the SIM reader twice just incase of faulty 'new' hardware. Checked the photobucket picture shown above and have no continuity on the red wire from SIM reader to GSM board. Whats the best method of running a jumper. I don't have a board view of that part of the card.
由完成的 分享
添加一条评论
Same issue, here is what works for me:
  1. Powering it off sometimes help.
  2. Toggling airplane mode also helps.... after doing it MANY times
Apple products is only a fashion statement, in the real world they don't have durability.
这个答案有帮助吗?
得分 1
1条评论:
Airplane mode method worked first time! Thanks!
由完成的 分享
添加一条评论
Found out a method from cleaning coins, that applies to SIM-Cards. I had the same problem. I've cooked the sim-card in salty water with a bit of aluminium foil in it --> This takes away the oxidation from the metal on the chip. I've put the chip back in and it was instantly recognised! Hope that helpts
这个答案有帮助吗?
得分 1
2条评论:
thnx dude that helps :D and works like a charm but i didnt cooked it just clean it up with w knife :P and it's ok
由完成的 分享
it worked i just scrub it thankis
由完成的 分享
添加一条评论
NO SIM problem can happen to iPhone and iPad. It happen because the sim card is not connected to it place.
This method is worked for me. And i Hope it work for All of you too.
Here's the method:
1. Remove the sim card
2.Remove the Touchscreen, LCD and LCD Shield Plate.
3. Push down firmly at sim card slot. (Like pushing a button)
4. Insert the sim card, and see.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Michele Pighi 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 30
总计 15,967
