跳转到主内容
问题已关闭
White screen (nothing else). Works perfectly with external screen.
Hi Everybody,
My MBP suddenly went white while I was watching a movie. I manually restarted it but it only displays white on the screen and nothing else (no logos, no spinning balls - the sound is working fine though).
I could use it blindfolded (I can log into it, run Terminal.app then type 'say hello' and I can hear 'Hello') so I connected external screen and confirmed that everything is working fine.
Questions 1: What are the chances that it is LVDS cable issue (how can you test without buying one:)?
Questions 2: Is it definitely screen problem?
Questions 3: If it is screen problem, can I replace the screen from my old MBP (Apple MacBook Pro "Core 2 Duo" 2.26 13" (SD/FW)) - will the screen fit?
Thank you very much for all your answers and concerns.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Please give us the last three figures of your serial number
完成的
...H2H (thanks for looking into it!)
完成的
See if you have another serial number, that one may be for the logic board
完成的
Full S/N (from Invoice): C02F9XPVDH2H
Product ID: MC724X/A
完成的
添加一条评论
2个答案
已选择的解决方案
DIY "shade tree" test procedures are pretty limited. Since the external monitor works fine the problem is most likely in the internal chain... the cable would be the easiest cheapest place to start. I know of no DIY way to test/eliminate the cable other than swapping.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 2
1条评论:
I will try to swap the cable out. I don't mind going and buying a spare screen but kinda afraid that both of them do not solve my issue. I will let you know how I go. Thanks for your answer, machead3
完成的
添加一条评论
You could take it to a genius bar if you're still in warranty.
这个答案有帮助吗?
得分 1
1条评论:
Not under warranty anymore:) How much would it cost just to get it examined, do you know by any chance?
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 501
