跳转到主内容
加入维修社区 - 创建账户
Apple Wireless Keyboard 的维修指南与支持。无线连接并操控你的 Apple 电脑。
Factory reset or re-install firmware?
The recent firmware 1.1 update appeared to install correctly.
BUT, since the update the keyboard does not work properly - random ' characters and shift key not shifting case.
Attempts to reinstall 1.1 update or 1.0 updates are blocked by - "Your keyboard is already updated!"
Any secret key combo to reset the firmware or force a new (or old) update?
Or do I now have a useless keyboard?
Mac Mini. OS X 10.6.3 aluminum bluetooth keyboard (2007 3 battery)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
What computer and OS are you using? Ralph
由完成的
OS X 10.6.3 - it was the automatic update that included the keyboard firmware update that caused my problem.
由完成的
添加一条评论
5个答案
最有帮助的答案
Here is the Apple paperwork for the update giving you problems. It appears to list steps to be taken after install. Maybe this will help you. Ralph
http://support.apple.com/kb/HT4010
这个答案有帮助吗?
得分 2
1条评论:
Thanks for the suggestion.
Yes, I did that immediately. It reports the correct version number for the new firmware having been installed.
Of course, being very user friendly it reports the version in hex, but I know how to convert 0x141 to 321.
I am quite surprised Apple expects their users to do this. I have gained a new respect for the average Mac user.
由完成的
添加一条评论
did you try the troubleshooting from here ?
maybe this would help to get mor information about the non (or wrong) functioning keys
这个答案有帮助吗?
得分 1
1条评论:
Thanks markus. It sees the same thing as any app. The keyboard is sending bad info.
I borrowed another keyboard and it works fine.
The problem is definitely in the keyboard and requires reloading of the firmware, which apparently loaded badly (despite giving no errors).
由完成的
添加一条评论
I have 2 Aluminum Apple keyboards ruined from an update of my macmini. pretty upsetting. apple is the new Microsoft. Apple updates used to be stable now they are shyt. one has non working keys while pressing shift another has a repeating number on startup for no reason.
这个答案有帮助吗?
得分 0
添加一条评论
This works...
resetting BT keyboard
Basically, you need to hold the power button the ENTIRE time you pair.
Try and see if it works.
这个答案有帮助吗?
得分 0
添加一条评论
The A1016 Mac wireless BT keyboard WILL work with Mavricks with no additional software, I dug out my old keyboard and put new batteries in and it attempted to paired up, but I had to remove all the other devices and then pair. After that you can pair up your other devices. I had to have patience, but it got there
这个答案有帮助吗?
得分 0
1条评论:
how did you remove all the old info from the A1016? I just found one that works perfect but when i try and pair with it, it asks for the keyboards pin number... and it say's the old owners name. i bought it from an electronic recycling store, so no way to contact original owner
由完成的
添加一条评论
添加你的答案
Peter Jennings 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 43
过去 30 天: 62
总计 55,553
