跳转到主内容
1.4GHz (or 2.1GHz) Processor, 2GB (or 4GB) RAM, 128 GB memory, 13.4" display
10 个问题 查看全部
问题已关闭
How do I replace the motherboard?
Hey guys, I was just wondering how I would be able to replace the motherboard on my Adamo 13? I can take it apart fine, and I can take the motherboard out without a problem, but I can't seem to get the most important cable back in, which is the one that I imagine would be the power control board cable (It's on the underside of the board next to the video cable.) So anyway, I just wanted to know if anyone has a video, picture, or just a tip on replacing the cable without damaging anything? Thanks guys!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Connecting the power board small ribbon to the motherboard is the problem. If your remove the magnetically attached cover at the back behind the screen you can then remove the screws that hold on the screen clutch cover, once that is removed you can get at the ribbon socket and secure the connection. It's all about access!
这个答案有帮助吗?
得分 2
1条评论:
I love you! Haha Thanks for the answer!
完成的
添加一条评论
Here is a link for replacing the motherboard. Good luck.
http://www.laptopinventory.com/LaptopInv...
这个答案有帮助吗?
得分 1
2条评论:
Sadly, this is a general video which I've stumbled upon many times, but thanks anyway!
完成的
Advertisement to sell parts, this is not for a Adamo 13 it is a generic video, no help at all.
完成的
添加一条评论
Szymon, take a look at the teardown right here ans see if that helps you out.
这个答案有帮助吗?
得分 0
添加一条评论
It can be an exhaustive task but if you are not confident about you technical skills then try not to attempt it or alternately you can take it some local hardware shop paying few buks and get it replaced. If you want to do it by yourself then find some online tutorials on YouTube then follow the step by step instruction.
这个答案有帮助吗?
得分 0
1条评论:
@david chase , so how does the OP do it?
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 3
总计 615
