跳转到主内容
Is a A1021 compatible with a A1036?
ac/adaptors
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
All iBooks can use either of the AC adapters you mention (45W, and 65W). PowerBooks use the same AC adapters as well, with the distinction that 15" and 17" PowerBooks need 65W AC adapters, and will not power on at all with 45W. But if you have an iBook, you can use either, and there will be no noticeable difference between the two.
这个答案有帮助吗?
得分 2
4条评论:
Thank u 4 your outright answer. I was worried that i might mess up my Apple.
完成的
+ Ralph
完成的
Thanks! The AC that Ralph pointed out is also a good option if you want to save some money. The only negatives are that with generics the extension cord is usually a couple feet shorter, and there is no green/amber light around the power plug letting you know if the battery is charging, etc. But if those things aren't important to you, again, it's a good way to save some $$$.
完成的
nice answer +
完成的
添加一条评论
If its a ac adapter you want this one is good for most laptops. Ralph
[关联产品丢失或禁用: IF113-039]
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cynthia Fleming 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,909
