跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
问题已关闭
Replaced Digitizer/Screen, possibly bad digitizer?
Hello.
My cousin's Ipod 4th Generation here. Replaced the digitizer/screen that was cracked pretty badly near the bottom. I repaired a 2nd gen before and followed steps carefully.... but despite that, i hooked up the digitizer cable and performed a quick test before putting everything back together.
I get no touch (or very wonky touch at best). I cannot unlock the screen. Does the touch have to be put back together in order to get correct calibration? Or is it possible to just get bad digitizers from repair shops?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Zack Whipkey, I never had to do any calibration but if your digitizer is "or very wonky touch at best" I would think that you have a bad digitizer. Yes, it is possible to receive a faulty digitizer, actually happens more often then one would think. If everything else is properly connected, it is the digitizer. Speak with the vendor and get it replaced. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 595
