跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Logic board with vertical socket
I'm trying to replace a logic board on MB Core 2 Duo (non-ES). Some of the boards I came across specify they are "with vertical socket type" or "vertical (snap-on) slots for heatsink." How can I check compatibility with the MacBook I have?
- Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Sorry for the massive delay in responding!
The Core Duo MacBooks randomly had 2 different connector types for the heat sinks. You can see pictures of the 2 different connectors here. I suspect that this distinction is what is described by "vertical socket type" or "vertical (snap-on) slots for heatsink."
Regardless, if you order a Core 2 Duo logic board, all Late 2006 and Mid 2007 version boards should have the same connectors. The Santa Rosa versions and Penryn versions change most of the connectors, and are therefore incompatible with Core Duo and Core 2 Duo (Late 2006 and Mid 2007) machines.
Because so many different companies call these parts so many different things, here are the things you would need to make sure are on the board you order:
  1. JST connectors for the heat sink (seen on the left side of the comparison picture here)
  2. a non-ES battery connector (2 continuous rows of pins on the board, explained here)
  3. Standard "4-wall" connectors for speaker connectors (seen above the right corner of the left RAM slot on this product, as opposed to the JST connectors portrayed in the same place on this product)
Sorry this is so confusing! Apple didn't exactly make these boards cut-and-dry.
Good luck!
Replace a 1.83 GHz logic board (motherboard) compatible with the MacBook Core Duo model laptop. Fix processing issues like unexpected shutdowns, reboots or water damage. Included Ports: Mini DVI Video Out, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in, Audio out.图片
产品
MacBook Core Duo 1.83 GHz Logic Board
$49.99
Replace a 2.16 GHz logic board (motherboard) compatible with the MacBook Core 2 Duo model laptop. Fix processing issues like unexpected shutdowns, reboots or water damage. Included Ports: Mini DVI Video Out, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in, Audio out.图片
产品
MacBook Core 2 Duo 2.16 GHz (non-Energy Star) Logic Board
$99.99
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Wait for Ben Eisenman to sign on. He works with iFixit. He's the very best parts man I've ever met.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
teeeveee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,273
