跳转到主内容
加入维修社区 - 创建账户
内置的 Beats Audio™ 技术为你提供毫无妥协、录音室级别的音乐、视频及游戏音效。它也是一款功能强大的全能机型,配备双核处理器、色彩明丽的 4 英寸清晰显示屏以及领先同级的摄像头。
Cracked touch screen panel
My sister has a HTC Desire X phone.
Link: http://www.htc.com/nl/smartphones/htc-de...
It has a crack in the top screen only. The display itself is not damaged.
Can i replace the top screen. Where can i buy the parts?
Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
I have HTC DEsire X phone,which top screen is damaged but display is ok,it is working.May i replace the top screen.where can i buy the parts.Thanks-Kiran
完成的
am using htc dsire x,my power button is totaly damagd,how to replaced the buttn....
完成的
Display and touch is damaged
完成的
My phone modle is htc desire.can I replace only a top screen glass.bcz touch with lcd display 's cost is high
完成的
My phone is htc desire x in which display has been cracked but touch s working.. Nd battery has a poor problem.. Can u replace battery nd display????
完成的
添加一条评论
9个答案
已选择的解决方案
The screen can be replaced.
you can find the part on ebay:
http://www.ebay.com/itm/Touch-Screen-Dig...
cheers
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
最有帮助的答案
You will need an lcd separator machine to separate the lcd from the glass as they are glued together and it needs to be put on a special hot plate. Tutorial and lcd separator machine reviews can be found at www.lcdseparatormachines.com if your interested..
这个答案有帮助吗?
得分 1
1条评论:
I have HTC DEsire X phone,which top screen is damaged but display is ok,it is working.May i replace the top screen.where can i buy the parts...pls hlp me..
Michael
完成的
添加一条评论
Be carefull! Hade the same problem with my sisters phone. I first tried to replace the Digitizer Glas, but its full glued on the LCD screen when I tried to seperate both the LCD broke. You have to replace the whole display unit. I bought them from ebay. Didn't find it on ebay.com but on the german site. It's about 90€
http://www.ebay.de/itm/Original-HTC-Desi...
Even this is the whole TOP-Unit it was still not very easy.
Hope I could help!
这个答案有帮助吗?
得分 0
添加一条评论
Hello
I´ve found it on ebay more cheaper.
http://www.ebay.es/itm/380739140385?ssPa...
I´m waiting for receive it and create a guide to all of you!
这个答案有帮助吗?
得分 0
1条评论:
i needed a new glass for mine which is a htc desire 310 and found my glass on ebay it's coming form hong kong
完成的
添加一条评论
hi, yes be careful , Bernhard is right the digitizer glass is stuck glued with the lcd screen and it broke with me as well so i needed to change the whole display unit. i found it on ebay and it's cheap :
http://www.ebay.com.au/itm/for-HTC-Desir...
i ordered it and still waiting for it
这个答案有帮助吗?
得分 0
添加一条评论
Had anyone got some kind of repair-guide?
I only found this video:
https://www.youtube.com/watch?v=hzRsLDah...
这个答案有帮助吗?
得分 0
1条评论:
Hello, I´m working on a repair guide, hope to finish it on this weekend.
完成的
添加一条评论
Did anyone bought some not original lcd and glass replacer?
I'm not sure if they are worth anything.
这个答案有帮助吗?
得分 0
1条评论:
Hello, yes, I have bought 2 lcd+touch non original ( but with the HTC logo) and they works fine. The point is to glue properly the piece to the phone, because sometimes it comes out.
完成的
添加一条评论
how to stick the digitizer to the display\front pannel
.please help
mine is not sticking
i cleaned it with glass spray also
这个答案有帮助吗?
得分 0
添加一条评论
what you have to do is heat the screen up with a hair drier or hot blower and then remove the screen
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 24,612
