跳转到主内容
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
301 个问题 查看全部
How to adjust valves on 1988 Chevy 350 small block v8?
I tried following the repair procedure in the chilton's repair manual but now the engine has a distinct ticking sound coming from the engine valve cover area that I did notice before. The repair started with replacing the valve seals because of a lot of smoke during initial start up that eventually went away after running the truck for a few minutes.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Rick, bit of a pain and can get messy :"
1. Warm-up the engine and remove a valve cover.
2. Restart the engine and let it idle (as slow as possible to prevent massive amounts of oil splashing around)
3. Loosen an adjuster nut until the lifter clacks. Go a bit more so that the lifter can fill itself with oil. SLOWLY turn the nut back down until the clack diminishes then stops.
4. Go 1/4 more turn and move on to then next valve.
5. Do this for all 8 valves then go back and turn them ALL down 1/4 more turn each.
6. Do this one more time so that you have a full 3/4 turn of pre-load on the lifters. Sometimes, 5/8 is better than 3/4 so only go an eighth of a turn on the last go-around. Repeat the procedure on the other side.
7.Stock lifter settings are usually 1 full turn. The looser you leave them, the better top end you'll get and it'll help the exhaust valves stay a bit cooler as well.
8. The reason you only go a quarter turn at a time is to give the lifter a chance to stabilize. Otherwise you'll stall the engine if you try and crank the full 5/8 or 3/4 turn in all at once. from here Check on here to see how to do it without running the engine. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rick 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 22
总计 20,172
