跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
not charging replaced battery
Dears
Please advise me in something
I received the new battery i ordered from you for my iphone 3gs.
I replaced the dead old one easily without problems.
After 2 days of proper functioning i had to recharge the battery.
This never could happen!!! the new battery didnt charged! It seems to try to charge but after a second switches off and from the begining again!
Did i make anything wrong with the inside connections?
Please help i dont have a phone and i need it for work
Many thanks
Markos GREECE
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
mmarabotos, make sure that you do have the right battery. the way it behaves, sounds like you either have the wrong battery or a battery with a bad circuit. Contact ifixit sales on here http://www.ifixit.com/Info/contact and I am convinced that the staff will make it right. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
Hello Markos,
Replacing parts in your Cellphone is always a Risk to take.
I would recommend to read the guide again u used and carefully re-do the steps. "This helped me alot of times" Did u tried another Cable for the Iphone maybe it stopped working?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mmarabotos 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 224
