跳转到主内容
Pavilion dv1000, Intel Pentium M 1.5GHz, 512MB RAM, 80GB hard drive
Why won't my screen work?
My screen would first flicker on and off occasionally for a couple months until finally it did not light up at all. I can hold a flashlight to it and the screen does work just fine, it just doesn't want to light up. I tried replacing the back light but that didn't help my case any. I also tried connecting an exterior monitor but it doesn't recognize the monitor at all. Any ideas what this could be? And roughly how much would cost? Thanks for your help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
Cassandra, great way of checking:-) Normally I would have said that it is your inverter or your backlight that has failed. Since you found out that it works but it stays dark. The only thing that points another direction is the fact that " I also tried connecting an exterior monitor but it doesn't recognize the monitor at all. " this would be a problem with the video card. The external monitor and the LCD use a separate pathway and the external monitor would not be affected by a bad inverter or backlight. There is not really a good way to check the inverter unless you have the right tools. I think I would replace the inverter with the cheapest one I could find, something like this or from here and replace it by either following this video or by downloading the service manual from here. The order of failure for this would be 1. inverter, 2. LCD CCFL, 3. GPU (motherboard). So for your cost this could be anywhere from $20 to $100's depending what you find. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Cassandra 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,660
