How to Remove usb port because of damaged pin and solder new one
I need help in de soldering and placing my new replacement ..I can't seem to find help on this topic i dont want to buy the whole cable with usb port i wanna solder a new one in
will, I suggest you use this teardown to disassemble your phone. It is not a guide, but does give you a general idea on how to get it accomplished. Remove the logic board. Desolder the data connections from the micro USB port on the front. Desolder the four points that hold the port to the logic board from the back. Remove the port and replace with a new one, available at places like this. Reassemble your phone. Hope this helps, good luck.
这个答案有帮助吗?
My question is after unsoldering the four points, are the data connectors solder as well or no? i am also doing the same operation.
Yes they are.
so then i would also have to unsolder the data connectors?
Yes.........
One quick Q... which are the data pins that are for the ground from left to right?
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 6,672
7条评论
will, what exactly is it that you are looking for? How to dismantle? where to find the part? How to solder it on?
由 oldturkey03 完成的
how to dismantle the usb charger part correctly and install it correctly I already bought all the parts I need ..Bought a 5 pack of USB ports
由 will 完成的
Already have a soldering iron and the tools to take apart the phone
由 will 完成的
Thank you buddy... needed to know those easy details you just mentioned :) will report once I get this done
由 will 完成的
best of luck to you:)
由 oldturkey03 完成的
显示更多的2条评论
