How do I know if the management ic is damaged?
hi, my iPhone 4 is dead only turn on when i connect the wall charger as soon i disconnect it the phone turns off i want to know if is the management ic or the real problem, i also changed the battery and clean the motherboard with alcohol....i don't know what to do any more pls help.
5条评论
what is the voltage on your battery connector with the phone being plugged in. Measure the left and right outside contacts.
由 oldturkey03 完成的
Just wondering, is this linked to my issue as well? Here: iPhone 4 After Repair Stuck on Apple Logo & Cannot Restore
It does the same thing when I unplug the iphone 4, it just immediately dies.
由 asdfADRiAN 完成的
Very possible you won't know unless you test with a multimeter or a working battery. I highly recommend taking a closer look at the board and checking if you damaged something. Software restore is not going to fix the issue. .
As for the microphone problem I can almost guarantee that the problem is the audio IC (located on the top left corner of the logic board- you have to take the logic board out to see it) You can resolve the issue by removing a part of the heat shield metal and putting something like a cushion (I used folded paper+tape) to put more pressure on the IC therefore completing the connection.
由 Alfy 完成的
i have a problem with my iphoen 4s
it shows error 50 in restoring iphone
i think it is power management ic problem
plz give me a solution
由 Aashak meeran 完成的
How to check if the ic is problem with multimeter?
由 Animushi 完成的
