跳转到主内容
型号A1288,闪存容量:8、16及32GB
451 个问题 查看全部
问题已关闭
Replaced digitizer, touch still not working
Alright so I'm relatively experienced at fixing iDevices, but I'm not sure what to do at this point. I got a 2nd Gen iPod Touch from someone a couple years back for cheap because the digitizer was broken, so I replaced it and it worked fine. So I gave it to my brother, and he broke the screen, and for this past Christmas his gift was a screen replacement. It worked great for about a week, and then the touch wouldn't work. So I was thinking the cable came loose, and I took it apart, and as best I could tell it was just fine. After tinkering with it I noticed that the cable was torn - I think I must have torn it without noticing. So I just bought a new one off of eBay, and that digitizer won't work on this iPod either. So if it isn't the digitizer, and on a quick inspection the connector on the logic board looks fine, what could it be? Any guesses or suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
As of this point I haven't made any progress. Any ideas?
完成的
添加一条评论
1个答案
已选择的解决方案
If the touch does not work despite a new digitizer and the connector is okay, no bend broken or corroded pins, the only other thing should be the touch IC I believe that the iPod 2 uses the same as the iPhone. No a who;e lot of schematics or diagrams out for the iPod....
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 680
