How I make the water cooler
is there a dial for coolder water
Sol Kay, looks like there is no setting.
Water not hot or cold enough
Temperature limiter tripped. •Set the hot and cold power switches (on the back of the dispenser, if equipped) to the O (off) position. Wait 5 minutes; then set the switches to the I (on) position. Unplug unit for 5 minutes if model does not have separate power switches. Wait 30 minutes for water to heat or cool. Hope this helps, good luck.
这个答案有帮助吗?
Water still not cold
Water not cold
IF your temp is set to coldest.. add ice. A cheap counter top ice maker would be perfect beside the cooler.
这个答案有帮助吗?
过去的24小时: 2
过去的7天: 19
过去的30天: 89
总计 5,371
