跳转到主内容
MacBook Pro 13寸显示器版本
9745 个问题 查看全部
问题已关闭
Is this LCD compatible with MacBook Pro 13" Mid 2012 model?
I tried doing some research online but could not find any specific information on LCD compatibility across all MBP 13" computers... Thought maybe you guys could help...
Here is the LCD:
http://www.amazon.com/MACBOOK-LAPTOP-SCR...
Here are the specs of the computer I am looking to replace the LCD of:
http://support.apple.com/kb/SP649 (13 inch model)
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
11条评论
First - If your screen not working with no physical damage you should get it serviced by Apple as you may have an extended warranty on it. If you dropped your system then your options are limited, I would ask this supplier for more details before forking over your cash.
完成的
Whenever you need to find out about compatibility it is of upmost important to post the number from the panel itself. Even within the same make and model, Apple and other manufacturers, still may use different panels or different version. This could be as simple as a different connector, which will leave you stuck. So if you have at least one panel number, we could see if it might be possible. The first thing to do would, be to do as Dan suggest.
完成的
Okay so here is the first piece of information. The panel that you want to purchase is a B133EW04 manufactured by AU Optronics.
完成的
So are you saying I would have to take off the glass and find the number on the actual LCD? Or would this LCD work?
http://www.amazon.com/AU-OPTRONICS-B133E...
Thanks
完成的
patrickswalls,that is correct. It will also help if you can give use the last three digits of your serial number. that way we could properly identify your computer and can possibly narrow it down a bit. Right now your choices are Samsung/AUO/LG but we do not know which connectors you have on your computer etc. The easiest of course is to identify it by the number on the panel itself. The LCD's you pick could all fit, but unless you know which one you have, it's a guess.
完成的
显示更多的6条评论
添加一条评论
1个答案
已选择的解决方案
Yep! You'll need to open your system to find out what LCD panel you have to match it up. Again, this should be your last option not your first if your system is not physically damaged.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 526
