跳转到主内容
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
139 个问题 查看全部
What is the ets off light for in a 1997 Chevy Cavalier?
the ets off warning dash light is on in my car what is a ets
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
Is your check engine light on as well.
完成的
yes the engine light is on
完成的
So what does it mean when ets and check engine light is on?
完成的
Check engine light is on and ets
完成的
添加一条评论
5个答案
已选择的解决方案
Susan Syme, you are probably talking about the Enhanced Traction System (ETS) warning light. It will turn on when the engine computer sees a problem. The ETS system monitors wheel speed via the Anti-lock Brake System (ABS). If the ETS system sees a wheel spinning due to snow, ice, rain etc., the ETS computer sends a request to the vehicle's engine computer to reduce torque. If your light is coming on when you are driving in slippery conditions, this is normal. If it staying on all the time, the ETS is either turned off or you have another problem. I would suggest to have it scanned and see if it throws any codes. Most of the larger automotive accessory places like Autozone offer a free scan. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
1条评论:
try a new fuel cap, worked for mine
完成的
添加一条评论
How do you turn the ETS on?
这个答案有帮助吗?
得分 2
2条评论:
What exactly are you looking for? I am a bit confused by your question? does it mean your light is on
完成的
yes the light stays on
完成的
添加一条评论
Hi abcdshirley,
It seems as though there may be a couple of things wrong with the car.
This is from the owner's manual for a 1997 Chev cavalier. It describes why the ETS light may be on, (either because the ETS has been turned off or that there is a fault with the system.
This is also from the manual and describes what to do in the event of a check engine light condition. I have read that AutoZone USA will scan the ODBII port for free to see what codes are present to assist in finding out what the problem is.
Here is a link to the complete manual.
http://www.vadengmpp.com/owners-manual/c...
Hopefully this is of some help.
这个答案有帮助吗?
得分 2
2条评论:
I got all excited about getting a free manual. But it says the site can't be loaded 😕
完成的
@dellajones90661 Unfortunately, that's the nature of the Internet; you can't necessarily count on any given link being good forever. Given that one is seven years old, it's not unusual for it to be gone by now.
However, you know the old "when one door closes..." saying; even though that one doesn't work, here's one that does, at least as of this date.
https://www.dezosmanuals.com/wp-content/...
完成的
添加一条评论
ets light stays on all the time.
这个答案有帮助吗?
得分 0
2条评论:
had mine checked .resulted in leak in the evap system
完成的
put a new fuel cap on cleared the code problem solved
完成的
添加一条评论
I got a code for bad fuel injector #4…. will have DH change out all 4 then see how that does.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Susan Syme 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 17
过去 30 天: 72
总计 35,757
