跳转到主内容
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
197 个问题 查看全部
问题已关闭
The temperature is about 90° and once it reaches 100°
sorry!
my friend give to me an old powermac g5 for big problem.
after mac os start, the temperature is about 90° and once it reaches 100° goes in protection.
i see no fluid loss, but i think the problem is with cooling.
any idea? thanks
this is solution? http://www.saunalahti.fi/~holindho/g5-qu...
really thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Is that 90 degrees F or C
完成的
is celsius degrees :(
probably i have to change water pump and get new liquid! it is not easy but I groped with the link step.
if I succeed, I will proceed with the calibration fan with ASD Dual Boot 2.5.8
完成的
添加一条评论
1个答案
已选择的解决方案
Run your Apple Hardware Test (AHT) from the original system installation disk. Hold down the "D" key on start up with the disk installed and see if its the coolant or possibly one or more of the fans.
这个答案有帮助吗?
得分 2
3条评论:
i will try, but all fans are going fast...
thanks for support
完成的
finally find asd but now the g5 won't start :(
his make fan check, and monitor don't show nothing :(
完成的
no moore idea?
really thanks
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 10
总计 366
