跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
Removed black matte finish from block next to cable shield
Hi!
I was swiping my iPhone 4s clean with isopropanol after an earpiece replacement, and carelessly also swiped the black matte finished block between the cable shield and the wifi grounding clip, and managed to remove what appears to be some sort of finish from the block. It is now partly shiny, maybe revealing a film-like surface underneath, but nothing else is "wrong", and the phone seems to function normally. What is that block, and should I be worried? What is that matte finish?
Thank You!
-Jonah
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Jonah, looks like you my have cleaned off part of the chip "that reportedly provides Wi-Fi/Bluetooth connectivity", this should not impair the function of it. The matte finish is sometimes applied to hide the markings of a chi, and sometimes it is just part of the manufacturing process. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
2条评论:
Well that's a relief! I was worried it was some sort of space-age grounding/shielding finish, and now that it's compromised the phone is going to go all haywire on me. But it's basically just tape, eh?
Off-topic: Actually it resembles a DIY pcb printing film called Press'N'Peel...
完成的
Just checked the Press'n Peel, I like that stuff:)
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 289
