My MP3 Player is not getting detected.
Hi,
I am unable to switch-on my MP3 player and it is also not getting detected when i try connecting it to system. Please help on this.
prrasuna, if it does not turn on and is not detected, I would start by replacing the battery.
这个答案有帮助吗?
It looks like the one I have. I had alot of trouble searching fo information about it as well. I got lucky 1 day and finally found what i was looking for. Try this address ( http://www.manuals365.com/swf/element/gc... ) Hope it helps.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 11
总计 1,426
Information on this is difficult to find. Any make or model numbers on your device?
由 oldturkey03 完成的
When i had one of these back in the day it powerd itself up when i connected it to the PC. Does yours power up ?
Did u forget and old battery in it and did battery acid leak out ?
由 Rockhound 完成的
Hi,
when I plug in my digital mp3 into computer USB port it will not detect on my PC but the digital was connected as charging.
由 Jaynald Aranas 完成的
Hi @ Jaynald Aranas
Was your mp3 player switched on?
If it was switched on, what is the make and model number of the mp3 player?
What is the make, model number and installed OS of the computer?
由 jayeff 完成的
hi i have the same trouble but with "you have to format it before use"
由 el Mansour Space 完成的
