跳转到主内容
20", 23", 和 30" LCD 显示器 发售于2004 于 2010年停产。
Monitor won't come on, power brick good, fixable?
My UPS just died, no sound, just shut off and at the same time the Cinema display went dark. Plugging it directly into the wall did nothing (no power light). Figuring it was a surge that killed the power brick, I bought a new power supply.
So, even when using the new power supply plugged into the wall the power-on light on the monitor remains dark.
My regular repair shop says can't be fixed, but I noted that mother/inverter boards are only $50 online. Can anyone tell me if they are mistaken and that it can be fixed or does it sound like time to take it to the recycling dump? (i.e. replace inverter board).
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
Is there any youtube on this? I have my cinema display disassembled, I have the multimeter, and I'm aware of certain points to try, but I get nothing so I'm not sure if I'm missing a step somewhere in all of this. I can't determine if my logic board is dead or powersupply isn't feeding enough.
完成的
Logically, this machine is a power supply, hooked up to a brain, hooked up to a giant pixel display, with some lights and other plumbing.
You know the power supply is good. Are the lights good? If no, maybe it's the internal power supply stuff that powers the lights. If yes, it might be the brain.
If any of the wiring looks worn/damaged, replace it, but this is pretty rare, since nothing internal moves.
完成的
添加一条评论
1个答案
已选择的解决方案
An inverter won't help if you're not getting power. Use a multimeter to test and trace down your power route. Here's one in case you don't have it: Digital Multimeter
Versatile multimeter with all the right functions for basic electronics troubleshooting.图片
产品
Digital Multimeter
$59.95
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
ejsprung 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 7,752
