跳转到主内容
加入维修社区 - 创建账户
2009 年推出的入门级 Photosmart 打印机。使用带有一次性打印头的惠普 (HP) 三色墨盒。
will not connect to a wireless network
How do I get my wireless hp printer to connect to a wireless network?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
Dors ont conect
由完成的
Je ne peux imprimer pas de conception avec hp
由完成的
添加一条评论
4个答案
已选择的解决方案
try this steps click on the link below.
http://h10025.www1.hp.com/ewfrf/wc/docum...
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
i will recommend to follow these steps to - make sure you have the right password of your wi -fi than go to the settings and uninstall the printer driver from the computer and download it from hp website and than install it again . check for any settings issue and you can also try to connect using WPS key for more information you can go to hp http://www8.hp.com/us/en/contact-hp/supp...and once you got it fixed restart printer and computer and print it again to make sure
这个答案有帮助吗?
得分 2
添加一条评论
Make sure you install the cd correctly and if nothing remove printer from devices and printers and add a new one and have it find it on the wireless.
这个答案有帮助吗?
得分 0
添加一条评论
If its easily possible then open the printer menu or follow the on booklet instruction to perform a factory reset. Once the reset is done then insert the installation disc and follow the on screen instruction which shall hopefully fix your problem. Good Luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tara Clifford 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 31
总计 9,240
