跳转到主内容
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
Why light won't go out and load won't start?
The light won't go out when the door is closed. Put a load in and it will not turn on.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Terry G, try to push the door switch button and see if the light goes off in the dryer. It is possible that this is caused by a bad door switch. You can check it for continuity with an ohm meter to make sure.Download the service manual from here for more information.Page 4-3 shows you how. If you are more of a visual person, check on here and here as well. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Terry G 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 332
