跳转到主内容
An audio/video receiver (AVR or home audio receiver) is a consumer electronics component used in home theaters that convert signals into sound.
280 个问题 查看全部
Anyone know where I can find a bridge rectifier for Denon DRA-335R?
My bridge rectifier has shorted out, and I need a new one. I can't find one that matches exactly to the one that shorted. Any help would be appreciated. Even if you can't find the part, information as to what the 20 and 11 mean would be nice as well.
Here's the part:
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
fryarludwig , this is a S4VB 200 Volt 4 Amp General Purpose Rectifier that has been discontinued by Shindengen and once stock has been depleted, it will no longer be available. Get the datasheet for the S4vb from here. Check with places like Mouser.com or Digikey.com for an equivalent. I get something like Digikeys PBPC603DI-ND. Hope this helps, good luck.
这个答案有帮助吗?
得分 0
3条评论:
Thank you for accepting my answer. Best of luck to you.
完成的
Good answer oldturkey03, Julio Mora
完成的
thank you JCM :)
完成的
添加一条评论
添加你的答案
fryarludwig 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 915
