跳转到主内容
Are all 12" PowerBook G4 keyboards interchangeable?
Hi, I'm getting an Early 2005 1.5GHz 12" PowerBook G4 (A1104 / last 12 inch model), but it has a bad keyboard. A friend of mine has one with a damaged logic board, I think it's the 867 model. Either way, does anyone know if all the 12-inch PowerBooks have interchangeable keyboards? Thanks!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Rick, from the numbers you provided the keyboard kit has a part number of 076-0982. Here is the compatibility of that:
Powerbook G4 Aluminum 12.1" 1.0GHz G4 (A1010) - Mid 2003 M9007LL/A
M9008LL/A
Powerbook G4 Aluminum 12.1" 1.33GHz G4 (A1010) - Mid 2004 M9183LL/A
M9184LL/A
Powerbook G4 Aluminum 12.1" 1.5GHz G4 (A1104) - Early 2005 M9690LL/A
M9691LL/A
Powerbook G4 Aluminum 12.1" 867MHz G4 (A1010) - Early 2003 M8760LL/A
Powerbook G4 Aluminum 15.2" 1.0GHz G4 (A1046) - Mid 2003 M8980LL/A
Powerbook G4 Aluminum 15.2" 1.25GHz G4 (A1046) - Mid 2003 M8981LL/A
Powerbook G4 Aluminum 15.2" 1.33GHz G4 (A1095) - Mid 2004 M9421LL/A
Powerbook G4 Aluminum 15.2" 1.5GHz G4 (A1095) - Mid 2004 M9422LL/A
Powerbook G4 Aluminum 15.2" 1.5GHz G4 (A1106) - Early 2005 M9676LL/A
Powerbook G4 Aluminum 15.2" 1.67GHz G4 (A1106) - Early 2005 M9677LL/A
Powerbook G4 Aluminum 17" 1.0GHz G4 (A1013) - Early 2003 M8793LL/A
Powerbook G4 Aluminum 17" 1.33GHz G4 (A1052) - Mid 2003 M9110LL/A
Powerbook G4 Aluminum 17" 1.5GHz G4 (A1085) - Mid 2004 M9462LL/A
Powerbook G4 Aluminum 17" 1.67GHz G4 (A1107) - Early 2005 M9689LL/A
Powerbook G4 Aluminum 17" 1.67GHz G4 (A1139) - Late 2005 M9970LL/A
Information is from here. I am not a Mac expert, nor do I pretend to be one. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
2条评论:
Thanks, looks like the answer is yes, all the keyboards are compatible!
完成的
yup, sure does.:-) good luck
完成的
添加一条评论
添加你的答案
Rick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 3,092
