跳转到主内容
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
146 个问题 查看全部
How to power on without power button on MacBook air late 2010?
I need to know how to jumpstart logic board power-on pads using a flat screw driver. I have the manual to isolate the problem but I don´t know where to put the screw driver.
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
Open the unit's back pane, locate the keyboard ribbon cable attached to the logic board, pin point the second pin from the left and 6th from the right and short them with a cable or crossing slim-line screwdriver. It would start up your Air.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
macpatagon, same answer as here. this is from the service manual of a MacBook Air (13-inch, Late 2010) "see if the attached image works for you (follow the red arrow:-)."
Hope this helps, good luck.
这个答案有帮助吗?
得分 4
1条评论:
It's a little hard to see in this image, but they're the two smaller pads on the bottom of the cluster. This solution worked like a charm for me. Thanks
完成的
添加一条评论
Hi, I have a Macbook Air 11" 2011, i found on a forum a safer way.Can't recall wich, but if you disconnect the battery cable to logic board wait a few seconds, reconnect, close your macbook back up, and then plug in your power cord it will reboot by itself. I just have to leave my macbook on all the time, but i guess it beats paying $200 for a new keyboard just because the power button went out.
这个答案有帮助吗?
得分 2
2条评论:
That worked great for me -- thank you!
完成的
A very simple and working solution, thank you !
完成的
添加一条评论
添加你的答案
Flavio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 17,955
