跳转到主内容
Canon's third iteration of their long-lens point-and-shoot camera design. Originally released in February of 2006.
27 个问题 查看全部
My zoom is slow, labored, and frequently gives a "lens error" response
If I use the zoom function on my camera, it usually moves very slowly and makes a chuggish sound. Usually it then beeps, turns off (does not unzoom) and gives a "lens error" message on the screen. The slow movement does not always result in a lens error, and sometimes the zoom moves quickly and then gives an error anyway, but usually it moves badly and then turns off. If I do not use the zoom, the camera does not have any other problems.
I suspect that either the motor is old or it needs to be cleaned, but I do not know how to do this.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Megan, it does sound like your lens is giving out on you. I uploaded the service manuals on the device page right here. Check for the heading Service Documents. This should get you to a point where you can clean and degrease your lens with 99% isopropyl alcohol. Hope this helps, good luck
这个答案有帮助吗?
得分 1
添加一条评论
Hi Megan, there is an eBay seller that fix Canon S2, S3, S5 and other SX models with lens error.
here is the link in case you need: http://www.ebay.com/itm/141334025954
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Megan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 780
