跳转到主内容
作为任天堂 Game Boy Advance 的一款升级产品,Game Boy Advance SP 于 2004 年 3 月 23 日在北美地区发布,它采用了方形机身结构和翻盖式设计。
How do I know if my SP is getting charged?
How long does it take for a Game Boy Advance SP to charge and does it have any lights that stay on or flicker to indicate charge? because when I plug in the charger to my SP an orange light will flicker only once then turn off. Is my SP broke?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Rosie Pacheco, sound like you are either not getting a charger, or your battery is no longer accepting a charge. Check your charger with a multimeter to see that it does supply power. Take the back cover off to expose the charging port. With the charger plugged in, you should get around 6V at the port. Then check the voltage on the battery ports and see what you get. If so, it may be time to change the battery and then re-evaluate. Check this video on how to change the battery. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Rosie Pacheco 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 44
总计 11,271
